Hello!
I was reading the terms and services and I had two doubts.
- Can not include if you want a plugin chat on the wordpress blog?
- I can not install a plugin that allows my current followers of my blog, in wordpress.com, to follow it also in wordpress.org? - That is my concern, because I do not want to lose the followers I have now!
Hello
Got it. And I will not urge chat plugin.
In my case you can not use the jetpack in flatness, because the followers that I have, follow my blog from the widget of facebook, for the most part.
Can I install the plugin that will allow my blog to be followed from facebook? - I am referring to this plugin, WordPress Follow Buttons Plugin – AddThis – WordPress plugin | WordPress.org
I just realized what you wanted to tell me. To install Better Follow Button for Jetpack – WordPress plugin | WordPress.org
I apologize!
I apologize!
No problem, if it doesn’t work (which it should) just use the other plugin.
And you dont need to apologize, I should have explained it from the beginning.
Good luck!
