Twitter Problem
Hello,
I am trying to submit my website to Twitter but it considers the link as a malware (epizy)
msxworld.epizy.com
Any suggestions?
Thanks and best regards,
Even without it being marked as malware, anti-bot protection scripts will stop it, unless the twitter bot is capable of executing javascript.
It doesn’t make it before (I was using another hosting) and it is EXACTLY the same website and html,etc…
Using another hosting? Is this a subdomain you are using? It says it could be an unsafe link. Just use Avast as evidence (so that people will click on the link, if they don’t believe you, they can check Avast, which will then say it is safe).
The problem comes from the profile in Twitter.
Twitter is not letting me submit my website link on my profile,always saying failed to post with a an explanation saying: malware link.
In the past,I used (on Twitter) like mywebbsitename.xxxxx.com and no problem at all,it seems Twitter refuses “epizy”
Have you contacted support (Twitter)?
You can file a case to have your site not marked as malware.
I will👍
Thanks a lot
