Trouble Finding FTP Remote Path
Hi, I am just getting started with this hosting site and I would like to use FTP so I can sync my code when I save it. I am using VSC with the sftp.json and the problem is I can’t get the “remotePath” to work. I would like to be able to instantly save and have my HTML/CSS files upload to my “soundwave” folder which is directly inside the “htdocs” folder.
My home directory: /home/vol4_7/epizy.com/epiz_24257415
Here is what I’ve tried in VCS using the sftp:Config :
“name”: “High Five the Sky Epizy Server”
“host”: “ftpupload.net
“protocol”: “ftp”
“port”: 21
“username”: “epiz_24257415”
“password”: “the password I was given”
“remotePath”: “ftp:/home/vol4_7/epizy.com/epiz_24257415/htdocs/soundwave/”
“uploadOnSave”: true
**My website URL is: http://highfivethesky.epizy.com/soundwave/index.html
**What I’m seeing is: no new changes to code edits; it is not connecting. I directly copied and pasted my username and password so I know those are correct.
**I’m using this software: Visual Studio Code
Thanks so much in advance! :slight_smile:
The remote path will be just /htdocs/soundwave/ if you’re connecting with the FTP host ftpupload.net. There is no need to input the complete Home Directory, as it’s the default root for the FTP server.
Wow thanks so much! It’s working now :smiley:
You’re welcome.
