Trillteamleon.com
Good day,
My site (trillteamleon.com) had an error 525: ssl handshake failed, so I did as the admin and many other solutions suggested… I went to Cloudflare and switched to flexible then changed my site’s url from https to http. The error 525 went away, but now I have an error of too_many_redirects. How do I solve this one?
Leon
Site: trillteamleon.com
If you are using WordPress, change your site path from HTTPS to HTTP.
You can do this in Softaculous or directly in your WP files.
OR if you added a page rule in Cloudflare or .htaccess, which is forcing to use HTTPS, just turn it off or remove it.
Yes, this is a known and ongoing issue. There was a topic previously pinned about this, but it looks like the pin expired. Here is the official announcement about this issue:
