What is Traffic Served Over TLS?
If you can open your website using HTTPS, there’s nothing to worry about.
Or they’re bots (?)
I alredy enabled https
Why there is still not secure
Might be possible if your website is’nt redirecting all http traffic to https. To do that, you need to ass a few lines of code into your .htaccess file
RewriteEngine on
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
Once this is done, your problem might resolve
What your seeing is extremely common, my website is the same:
It’s just the way Cloudflare handles different browsers and requests. Older browsers don’t support newer versions of TLS v3.0, and so they are forced to use an older version.
