Cloudflare has not been used before. I use your method to enable and disable cloudflare, but it remains unchanged. Do I need to disable cloudfare after it takes effect?
You can enable and then disable Cloudflare. This will reset your DNS records.
And as with most DNS changes, it can take up to 72 hours for the changes to be visible everywhere. While we update our nameservers instantly, that doesn’t mean the results are also visible to you right away.
I believe your website is fixed now.
Just a recommendation,
If you ever wanted to use cloudflare then attach your domain manually with cloudflare instead of using cloudflare integration.
