Error Message: Error establishing a database connection [And other, As I Didn’t Record them Yet]
Hello, I created a Website with my Custom Domain which is given above. I have Completely Free InfinityFree Hosting and I think it sucks.
The Speed: It is too slow. I mean Yeah You guys giving Free Web Hosting but What’s Up with this speed? Even My WordPress Dashboard crashes 4-5 times before connecting, Shows Errors like those given above for example, and more.
I don’t have that many plugins Like Only Less than 15 and they are for basic needs like SEO and Cache Cleaner For theme I have GeneratePress Which is Very Light Weight in my Opinion compared to Astra.
Do You Guys Have Any Solution for this or any configuration I can do to Solve this Problem?
Hey there, Your website works fine for me, but it takes around 22 seconds just to load your main file, and you mentioned that the servers are very slow, but in my case, I don’t think it’s a server error. I’ve looked into your HTML structure, and it seems you need to optimize it. Like using main style sheets and script files in a single folder rather than keeping them inside a few folders. And finally, your favoicon is taking a huge amount of time to load. And to prevent that, you should link the favicon to the HTML page; otherwise, it’s redirecting by default, which can cause your site to be slow.
Sure! Assume your project structure is like this
project/
index.html
styles/
main.css
scripts/
main.js
You should make it like this
project/
index.html
assets/
main.css
main.js
as you can see I’ve put CSS & JS files in a same folder rather than creating separate folders. This way server will find your files read them much faster.
favicon matlab label samjh le jaise teri instagram ya facebook ki profile ho vaise tuhne apne website ke liye favicon set kiya hua ose kehte hain favicon.ico and the last thing is wordpress k liye eh hosting me little problem ayegi tujhe because its free tho use paid version its not much expensive
A favicon is a small icon or collection of icons associated with a website. In short, it’s the icon you see in the browser tab.
By default, most Web servers check for a favicon. If it’s not found, it’ll give a 400 error. But it’s not a big issue. However, it’s better to link a favicon to the website.
WordPress has it’s own system for making pretty URLs for user facing pages and posts. They don’t have this for admin pages, because visitors don’t see those anyways.
Setting up .htaccess rules to manipulate the URLs of third party software (like WordPress) is dangerous because the software may not deal well with customized URLs, and cause all kinds of strange issues.
The Problem is Very Clear there is some error connecting to the database. However, the problem is that the given database server is different from Mysql.
Database Server in the Error: sql306.byetcluster.com
Actual Database Server: sql306.epizy.com
I didn’t do that.
So How Can I solve this problem?
This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at sql306.byetcluster.com could not be established. This could mean your host’s database server is down.
Are you sure you have the correct username and password?
Are you sure you have typed the correct hostname?
Are you sure the database server is running?
If you are unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress support forums.
Hello, Writing on this issue again.
I am not sure If I need to create a new topic but here I go.
I didn’t do that.
Also, there is a Change in the Password [I checked the wp-config.php file] Which I guess was randomly generated and the User name is a little differently written, [‘_3’ is there.]
Hey there, I think it’s probably an error with one of your plugins. I had a friend with the same exact problem a few years ago; his plugin kept changing the wp-config.php file due to a bug. Try removing some of your plugins.
If you are not sure which one to disable, you should disable all of them just for testing. After that, you can know for sure whether it’s a bug with your plugins or not.
