TLS Certificate is not trusted / The certificate is not trusted in all web browsers
The certificate is not signed by a trusted authority (checking against Mozilla’s root store). If you bought the certificate from a trusted authority, you probably just need to install one or more intermediate certificates. Contact your certificate provider for assistance doing this for your server platform.
I can’t even open your site (It just keeps closing), so I don’t know how we’re supposed to check the site.
Apart from that, using SSL Shopper, it says your Cert is fine. If you want almost full browser support, consider using Cloudflare with a proper domain (rather than a subdomain)
Thanks for checking the issue
I opened the sub-domain for redirection and it’s attached with SSL from infinityfree.net. So I think if the SSL going to work then it will work for all not only for the proper domain also for sub-domains.
