Title: Need outbound SMTP IP address for Brevo
https://www.legkacy.rf.gd/
Hello InfinityFree Support,
I host my website https://www.legkacy.rf.gd/ on InfinityFree.
I use Brevo SMTP (smtp-relay.brevo.com, port 587) for order confirmation and order status emails.
Could you please confirm the public outbound IP address used by my hosting server for SMTP connections?
I need this information to configure Brevo’s authorized IP restrictions.
Thank you.
Thank you.
I can’t give you an IP to authorize, because there isn’t a fixed one. Outbound connections from your website, SMTP included, don’t come from a fixed IP address. IP allowlisting for outbound connections isn’t supported.
You can see which IP your site is using right now with a PHP file containing this:
<?php echo file_get_contents('https://ifconfig.me');
That address is shared with many other websites and can change at any time, so it’s no use for Brevo’s authorized IP restrictions. The IP your domain points to is for incoming visitors, so it won’t work either.
The knowledge base article below covers this, along with the ports your site can connect to. Port 587 is allowed, so your Brevo setup is fine on that side. The IP restriction is the part that won’t work.
Here’s the article on outbound connections from your website:
