There are differences
(https://freewd.infinityfreeapp.com/)
(Not an error exactly )
(I made a website such that authorised users can upload images under a media tab, but they can only upload an Imgur link and the js code was made such that the site would fetch the image from Imgur . Although the code worked fine while testing in both codepen and node.js
When I updated the files in the file manager of infinityfree although it seems to updated the website but the media thing doesn’t work in the website when I enter the link nothing happens, can someone pls help me)
What page are you having trouble with? If it is password protected, provide a login we can use.
Anything in the console? What have you already tried to resolve this?
@Freewd
As a rule, the username and password are not checked via a javascript file
because anyone with basic knowledge can bypass it
Does that mean that your code uses node.js?
if the answer is yes then it is clear why it is not working because “Node” is not supported on this server
