The navigation bar is stuck to the top and is hidden from view
How do I get the navigation bar back to it’s original place, under the header instead of behind it at the very top. I have tried everything but no matter the changes I do the code it remains the same, I used to work fine, but now it does not and I need help. My website is dayrart.epizy.com.
This is how the nav is coded on the css
nav
width: 100%;
height: 70px;
text-align: center;
padding-top: 10px;
position: scroll;
Hello there,
Is this what you want your navbar should look like?
no it was just under the header, all five icons.
What it seems to me is that your browser simply caches the page (some bad variant that doesn’t reflect the real state) that’s why you don’t see any changes
Clear browser cache with CTRL + F5 or use private/incognito mode
On your last screenshot (from a local PC)
is that’s how it should look online?
if yes - then everything is fine (except your cache)
if not - please explain to us in much more detail
P.S. :+1: for notepad++
It worked!!! Thank you so much for your help!
