The key uses greater than 2048 bit rsa encryption, on free hosting we allow 2048 bits maximum
Hello team,
when i’m trying to upload my SSL i’m getting the issue
It’s already clear.
If you want to use the key more than 2048 bits, then upgrade your hosting to premium.
What is your question exactly? You have to reissue your SSL certificate with a 2048 bits key. If you generate the private key and CSR from our panel, that’s already the case.
