Test Website's Acting Very Weird
My Test Website : testingwebsites.gq
Is Acting Very Weird When I Opened It, My Browser Said: " testingwebsites.gq took too long to respond."
And My Primary Website : clicketyclacketyclic.cf Is Way Longer Than Ever Before (I’m Not Exaggerating)
They’re All In The Same Account. What’s Wrong With The Test Website And My Primary Website I Mentioned Above?
Here’s the error I am seeing.
When I Upload The Certificate That I Created In CloudFlare And Uploaded The Origin Certificate And Private Key, The Origin Certficate Isn’t Showing In The CPanel I Put The Origin Certficate In The CSR Section. And When I Click Upload Key It Still Didn’t Show, What Happened
Also In CloudFlare Dashboard I Put Always Use HTTPS ON
I had issues with the Origin certificate of Cloudflare as well. Apparently, you cannot use Cloudflare’s Origin certificate.
I Don’t Know, In The CPanel I Had Uploaded Both The Certificates And When I Click Upload Another Certificate Disappeared And The Private Key Is Still There.
@anon92301367 But The CPanel Is Asking For CSR And In CloudFlare They Didn’t Provide CSR
For the CSR issue, you can’t upload CSRs (it’s not recommended to do that, as it may be needed only one time to sign a SSL certificate), but you can only generate one.
But CloudFlare Only Issued An Origin Certificate And A Private Key, Do I Need Only Private Key To Use Configure SSL?
Because CloudFlare Does Not Give Any More Certficate Except Origin Certificate And Private Key.
Ah, and you can’t install Cloudflare Origin CA certificates on free hosting.
But How Is It Possible In My Primary Website I Use CloudFlare Origin CA On Them
Primary Website : clicketyclacketyclic.cf And Check The Certfifcate It’s CloudFlare CA
It’s Cloudflare CA only on Cloudflare network, but on our servers in your domain there’s still the self-signed certificate.
And My Other Website Except The Test Website CAN Use CloudFlare CA And Their All On Free Plan.
But to use Cloudflare CA you must use Cloudflare nameservers or our integration! It is also available as a certificate to install, but it’s not supported on free hosting!
Done That In My Test Website Long Ago
Actually Now My Test Website Worked Except With One More Problem The Browser Says Not Secure With Red Highlight In The Not Secure What Happened Now?
You changed the nameservers to our ones, but without installing an SSL certificate on our servers. Try my guide to install a GoGetSSL Unlimited Trial certificate:
Ok I’ll Try That Method In Addtion I’m Using Sectigo Certficate Yay
There Should Be A Community Tutorial In This Forum Other Than Knowledge’s Base And Because Knowledge’s Base Tutorials Are Very Limited And Only Regulars Can Post New Topic As They Are More Experienced.
I agree, and I’m also a Regular, so I can post in that non-existing category.
