Temp Mail Project
How interesting!
took me 1 hour with chatgpt to make (ngl chatgpt is sucks, i have to tell it fix the code for like 10 times to be like this stage, it is still very unstable but as long as you dont press f12, everything will be fine), btw can you use it and give me a review?
I don’t reccomed to use AI to make websites (belive me, I did it in the past, before becoming a web design student).
One of these this is that it scales up the images, instead of editing them in Photoshop (which is highly suggested for SEO, see Firefox tools), and that it doesn’t do it very well.
I recommend to take a course or a carreer.
BTW, your website is asesome!
And what hosting do you use?
secret shhhhhhhh
Oh, okayyyy
Try using GitHub Copilot Free tier
i only use chatgpt for the ui because i havent learn html css js yet, i only know php and python so i can only code backend, for frontend i have to use ai
Front-end development isn’t that hard excluding Javascript. You should actually always start with HTML, that is most useful when starting
Just the screenshot gave me enough information to tell that this is basically just a frontend for temp-mail.io.
Do they allow third parties to embed their service like this? It sounds like you’re abusing the APIs that they use on their website and are just impersonating a browser with your application. Which is not OK.
they do allow everyone to use api, also they have a public open api for basically anyone to use so i think thats fine, also mine version is way faster than the original one and have no ads so it is better than original
No… they don’t.
They do have a public API. But it’s not open, you need to authenticate and have a premium account. It’s not open, and it’s not for anyone.
What you appear to have done is is write (or generate) some code that uses their internal APIs by spoofing a legitimate web browser on their website.
Yes, it works, but it’s not allowed, so it’s definitely not “fine”. You’re just hacking and abusing their internal APIs, while simultaneously depriving them of any revenue from subscriptions or ads.
Will bookmark and use.
hmmm i wonder what is this thing, definally not open api and free…
I agree with the @Admin.
True, having a Temporary Mail service is something many may need, sometimes myself. While I like the generated contents, I don’t like the idea of someone abusing an API to make it work. I understand that you want to make a beneficial service, but abusing an API for your service to work is not a good service, not a good thing.
If you are using internal APIs, in the way the @Admin said:
You’re breaking rules. Technically you are “hacking”:
Which could lead to your website being suspended for ToS violations.
If I interpreted this question right:
Technically it’s not a secret. You’re either using InfinityFree Hosting or iFast/Net hosting.
fine ill make other api and host it somewhere in the world
