I created a new Subdomain, I put a file in it but it looks like this again
https://cv.halitergul.xyz/
[image]
[image]
Due to your domain being behind cloudflare, I cannot check, but you have created the record for the subdomain, but you have to add the subdomain in the vistapanel
You need to manually create a subdomain on your control panel > Subdomains, then after it will work fine. Use incognito mode or clear your caches if you still facing the same view of the subdomain.
I already created from subdomain
Can the authorities look?
Have you configured the subdomain name to your cloudflare dns? Make it sure that it’s pointed to your domain ip address.
Weird, usually the holding page happens when the DNS records on the nameservers haven’t updated
solved when configuring cloudflare dns thank you
[image]
Don’t forget to mark this topic as solved!
