Subdomain not resolving after 7 days — DNS_PROBE_FINISHED_NXDOMAIN
pancheria-willy.site.je
Other Information: El sitio fue creado el 8 de septiembre, la cuenta figura como Active en el client area, pero el dominio nunca resolvió, ni siquiera después de 7 días. Probé con check-host.net
What did you test exactly using check-host.net? I tested it, and even that specific website shows that your website is working from all their locations. The only exception is their location in Romania, but I chalk that up to their monitoring failing, not a hosting issue, when 50+ other endpoints from all over the world all show good results.
And just for the record, it is working fine from here too.
Did check-host.net show that the website was not working? If so, which test did you use (I used the HTTP test, since HTTP is actually what you need for a website)? Because the ping test will fail, which is by design, and doesn’t impact your website.
My best guess at this point is that something on your end is blocking access to your website, like a firewall, antivirus or other security filter, either on your computer or on your network. Try accessing your website from a different device or from a different network and see if that helps, so you know where you should start looking for what’s causing this.
