Subdomain for an e-commerce store
Hello
For a few months I have had my website here with my own domain.
Now I want to sell through a virtual store and use a subdomain and not use the address that the store gives me.
Domain: sif4.com.ar
Subdomain: tienda.sif4.com.ar
Yesterday I did the store steps to link my subdomain and also uploaded the ssl certificate for the subdomain. Up to that point everything seems correct.
But I can’t get the store page to appear when I go to the subdomain.
I don’t know if I’m doing this right, and it’s been 4 hours since I created those last two records.
I appreciate the help
Did you create the subdomain in the hosting account?
The site works fine for me:
You need to clear your DNS cache. The advice in this article can help:
If the page you’re seeing isn’t the one you want to see, then what @KangJL wrote above might explain why you’re facing an issue:
If you did this, you’re unable to use the subdomain as a CNAME record, which may explain why it does not work.
Yes, I created the subdomain on this hosting (infinityfree).
First it worked only with www.tienda.sif4.com.ar and now it works without www. I deleted the cookies, maybe that was it.
Thanks for your interest.
I will consider the post as solved.
