Sub domains not working
Hello there fellas! May i ask why my sub domains are not working? yesterday i connected my website to Cloudflare so that may be part of the problem?
From now, when you have a subdomain on a domain which is connected to cloudflare:
create a cname record named subdomain with value @ (for example if your subdomain is example.example.com, you’ve to add such cname record named example)
ok!
Like this?
yup.
ok! also while you are here may i ask why the images on my website are not loading? i changed the file format from .png/.jpg to webp now the images are not loading
Yes, of course your may ask! Just note it helps a lot if you can be specific in your question. So instead of asking about “the images on your website”, please include the URL to the specific web page and point out which images should be present but aren’t.
