Stream problem
https://ardakosova.com.tr
Why can’t I play the live broadcast on the website I just opened, but I can play the same live broadcast on the other site?
this error “Your browser does not support playing this video. Please try with a different browser. (I tried all browsers, there is no problem with streaming)”
Hi and welcome to the forum
I think you wrote the address wrong
Judging by your username on the forum, I think this is the right address
https://ardakosovatv.com.tr
Yes sorry.
my browser throws an exception and goes to debugging
for the first and second video in the list
Screenshot 2023-12-14 203839
but the third one works (and several more in a row)
But it doesn’t work either, although there is no problem in normal broadcasting.
Can you explain what is not working, where, etc.
thank you for help
when I have an ad blocker on, a lot of things break (which is to be expected)
when it’s turned off, I sometimes get a 403 for the stream, but that’s to be expected because I’m probably being blocked or I don’t have access
A lot of icons and other things are missing on the page, and that’s a problem with CSS and so on
the simplest thing is to open dev.tools (F12) and look at the console
after you refresh the page
and fix problems
when your site uses HTTPS then all URLs must be https and not http (mixed content)
you have to correct that
