The knowledge base article on the SSL CNAME records says the DNS changes take a few hours to roll out fully. During that time the client area may show the record as Ready only intermittently, or not at all. Once it detects the record, it says Ready and enables the Request Certificate button.
Your hosting account was only created a few hours ago, so this may just be that delay. Here’s the article:
I’m not sure that’s the cause, though. When did you add the _acme-challenge CNAME record in the control panel? And does the destination shown on the SSL certificate page right now match the one you added, character for character? That’s worth checking if you created the certificate order more than once.
All three DNS servers return the exact expected target.
However, the InfinityFree SSL dashboard still reports:
“No CNAME found — Not Ready”
I understand DNS propagation may take several hours. I will allow more time for the validation system to update.
If it remains stuck despite the record resolving correctly from both authoritative nameservers, could an administrator investigate the DNS verification process?
