Sidnei
April 9, 2024, 8:52pm
1
Hello, I did the whole SSL installation process to switch to HTTPS, but when I try to configure the sharing image for facebook, linkedin or whatsapp it gives me an error.
in the facebook debugger it appears: URL returned a bad HTTP response code.
I’ve used SEO plugins and they haven’t solved it.
my site https://autsid.com
Can anyone help me?
Thank you
Sidnei
Its working fine for me. Note that seurity system below may be blocking some stuff
InfinityFree is a website hosting service. That means that the hosting accounts we provided are intended for hosting websites. Websites contain pages that are accessed through web browsers. InfinityFree is not intended to be used for file sharing, API hosting, database hosting or background tasks/tools.
To help enforce this, free hosting enforces a security system that makes sure that anyone trying to access your website is using a normal web browser. This is done by checking whether the web br…
Check out this response in a similar topic:
Hi and welcome to the forum
The reason is this
But since you own the domain then you can use Cloudflare
and bypass that security system and at the same time use other CDN benefits
system
Closed
April 16, 2024, 10:43pm
6
