mysql1.free.nf
No Error message just won’t load
Hello! So, I have my domain: mysql1.free.nf and I am using it to send requests to my MySQL server but I can’t connect to the website without an SSL certificate. Whenever I try to make on sometimes it just keeps saying the domain ssl destination isn’t ready. Other times when the destination is ready it won’t stop loading and when I leave the page it resets. Could anyone help me?
KangJL
March 24, 2024, 4:40am
2
Make sure you do these
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
This article only applies to custom domains
Free subdomains (like your…
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
Please provide screenshot where you are stuck
Ok! I will check these out.
system
Closed
March 31, 2024, 4:51am
4
