Domain name: rat-ps.com
IP Address: 104.27.162.166
URL Tested: (https:domainname)
- Common Name: cloudflaressl
- Certificate Valid: from Aug 24,2020 to Aug 24,2021
- Certificate Issuer: Cloudflare Inc ECC CA-3
- Signature Algorithm : ecdsa-with-SHA256
- Force HTTPS : Your webserver is forcing the use of SSL.
- All items called securely!
if i go to http, the site loads but warns with no padlock(not secure)
if i got to https → (shows)
*** sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
I’ve been tinkering every possible solution but none works so far. console showed no warning or error.
your reply is greatly appreciated.
You need to force https. Read here:
Admin
4
I don’t see any SSL errors like that. Do you still experience this problem?
Testing your domain @UserQuery101 in https://www.whynopadlock.com/results/e90cac71-339c-467a-a361-99e142fa22da shows that it has no problems in SSL or any mixed content.
It also works on mine. I think the probable cause were:
- Insecure Network Connection (Client Side)
- The browser you use may dont accept SNI (older versions)
- The browser may not support your current website TLS version
And its rare and unusual problem.
system
Closed
6
