Step 5: Verify Installation on qartlinews.site
This is the SSL certificate that’s active on your site. If the domain is hosted elsewhere, it will show the certificate that’s active at that provider.
“Not Found” in Verify Installation is expected until the certificate is installed and has taken effect. The SSL guide says it usually takes a few minutes after installation, but it can take more than an hour. Until then, Live SSL Status and Verify Installation show “Not Found”.
So I need two things from you:
Did the certificate reach the issued state in the Free SSL Certificates page, and did you install it (the automatic install button, or manually under SSL/TLS in the control panel)? If so, about when?
Is qartlinews.site using InfinityFree’s nameservers, or a third-party DNS provider like Cloudflare?
The nameservers matter because the Verify Installation page says it shows whatever certificate is active at the provider where the domain is hosted. If the domain points elsewhere, it won’t find ours.
These are the steps for requesting and installing the certificate:
This one covers the “Not Found” delay after installation:
