Your connection to this site is not secure
You should not enter any sensitive information
on this site (for example, passwords or credit
cards) because it could be stolen by attackers.
Learn more
You have chosen to turn off security warnings
for this site. Turn on warnings
when i am trying to place order SSL , i got a warning : subdomain ssl are not required . it’s come with deafult. when i am trying to browse my subdomain it’s showing ssl error. and i am unable to install SSL from Other source.
you’re using the http version of your site, not https.
In this instance, because you’re using a sub sub domain, its not covered by the automatis SSL certificate. I honestly didn’t even know this was possible any more.
i was try to fix it by .htaccess force https .
RewriteEngine On RewriteCond %{HTTPS} off RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
but issue is not solved.
is there any options to fix it?
in 2024 i was faced same issue . i was resolved it by install ssl from third pary for 90 days.
now i am facing same issu but now i am unable to install third party ssl .
First of all, how did you even get a free subdomain ON TOP of a free subdomain?
Second of all, they ARE right, you dont need to issue a SSL certificate for a free subdomain, i have seen you website and its indeed showing certificate not valid (net::ERR_CERT_AUTHORITY_INVALID), Can you please share the screenshot of you trying to issue a SSL Certificate for this domain?
