SSL issue with website
hyperxtalk.com
Safari can’t open the page “https://www.hyperxtalk.com” because Safari can’t establish a secure connection to the server “www.hyperxtalk.com”
Server IP Address: 185.27.134.150
SSL Issuer: Let’s Encrypt
SSL Expires at: 2026-11-30
I ended up migrating to another hosting provider.
In case you were interested, the www subdomain does not work on free subdomains due to how ssl is configured. Using the base subdomain without the www part will work.
Ignore that, the correct answer is below
I believe OP is using custom domain
The www thing only applies to subdomains, not custom domains, so that’s irrelevant.
There is an ongoing issue with SSL certificates on custom domains which I think is responsible for this. I just created the status page announcement about it, please keep an eye on it for updates.
