SSL issue with free subdomain
workout.ct.ws
So I understand that there were some changes related to SSL recently. But even after the new changes, my website should have SSL since it is a free subdomain. However, I am getting SSL Protocol Error.
No issue
Do you have any idea why it could be like this on my side? I also sent the site to someone else, and they also had an issue opening it where it would show them that it is blocked by spectrum. Also, if you can tell me what exactly you entered to get secured website.
It’s working fine for me too.
It’s possible that a virus scanner or firewall is blocking access to your website. The ERR_SSL_PROTOCOL_ERROR you see can be caused by something intercepting and interfering with the connection to a website, which can also be caused by a deliberate filter.
Unfortunately, there is not a lot we can do about this, as this is likely a block on your end, which is not something we can solve.
All free subdomains have SSL now, and many browsers will try to upgrade the connection to HTTPS if they see it’s available, but you can also configure your website to enforce it.
