A Let’s Encrypt certificate for wirdigkoma.web.id was issued and the panel reports it as installed. More than an hour later, both wirdigkoma.web.id and www.wirdigkoma.web.id still serve a self-signed certificate.
Your post matches what our “How to install an SSL certificate” article says. After a certificate is installed, it usually takes a few minutes to take effect, but it can take longer than an hour. Until then, Live SSL Status and Verify Installation show “Not Found”, and browsers may show a self-signed certificate or NET::ERR_CERT_AUTHORITY_INVALID. The article says it may help to install the certificate again.
So your symptoms are what that article describes for a certificate that hasn’t taken effect yet. I can’t tell from here whether yours is just slow or stuck.
Roughly how long ago did the panel report the certificate as installed? And if you reinstall it, does an SSL checker such as the one the article links still show the self-signed certificate?
Two other topics from September describe the same symptoms. Neither has an answer, so they don’t tell us what fixed it.
Hello, following up: I reinstalled the existing certificate from InfinityFree on Nov 2, 2026 at about 19:12 UTC+7 and waited one hour. At 20:12 UTC+7, both wirdigkoma.web.id and www.wirdigkoma.web.id still fail trusted TLS validation.
Both resolve to 185.27.134.136. They now present a Let’s Encrypt certificate for wirdigkoma.web.id that covers both hostnames, but the server sends only one certificate. OpenSSL reports “unable to get local issuer certificate” and verification code 21 (“unable to verify the first certificate”); curl also fails certificate verification.
Could staff please check why the complete certificate chain is not being served? I have not changed the DNS records.
No certificate chain is being served because our hosting doesn’t support them for custom SSL certificates. It’s not perfect, but your website works fine without it, because any remotely modern browser will be able to find the required issuer certificates themselves. Automated access like cURL and other scripts will not be able connect securely, but those are not able to access your website anyway.
Do you still see issues with your website’s SSL when you test it in a browser instead of from cURL or OpenSSL?
