I installed the Let’s Encrypt SSL certificate through InfinityFree. The SSL page shows that the certificate is installed and active, but when I open nabawitransport.biz.id in Chrome, the browser still shows “Not secure”. Please help me check the domain mapping and SSL configuration. Thank you.
The domain uses InfinityFree hosting, and the domain nameservers are ns1.infinityfree.com and ns2.infinityfree.com. The certificate was issued and installed successfully, but Chrome still displays “Not secure”. Please check whether the SSL certificate is being served correctly for both the root domain and HTTPS requests. I have not deleted or changed any domain files while troubleshooting.
Can you click “Not secure” in Chrome’s address bar and tell me exactly what it says? Also, does the page actually load over https://, or does Chrome show a full-page warning first? Your other topic mentions NET::ERR_CERT_AUTHORITY_INVALID, and that’s a different problem from a plain “Not secure” label on a page that loads.
The two cases have different causes, according to the HTTPS article and the SSL install article.
If the page loads over https:// but there’s no padlock, the article says some images, CSS or JavaScript on the page are probably still loaded over http://. All URLs on the page must use https. You can look for “Mixed Content” in Chrome’s developer console, or search the page source for http://.
If Chrome shows a red warning page instead, the install article says Chrome can remember the old certificate for a few hours. It also says an SSL checker is the best way to confirm the certificate is installed correctly.
Your other topic about the “Not Found” Live SSL Status may be the same issue. Tell me which of these you’re seeing, and keep the discussion in one topic so the details don’t get split.
