I just installed the Comodo Free SSL via GoGetSSL.com and followed all the installation instructions for it. I’ve installed an instance of Wordpress on my domain name with https installation and installed the “Really Simple SSL” plugin to verify it and all, but when I visit the site I still get a “Not Secure” line item in the URL bar. Can anyone think of what I can do to fix this? Thanks.
Is the address bar white or red? Red means you’re using SSL but the certificate is not valid (which can happen if you just installed the certificate, browsers cache certificates for a while). A white address bar means you’re not visiting the website over SSL (try typing https:// before the URL yourself).
