How many hours do I have to wait until the certificate becomes valid and installed?
KangJL
August 17, 2022, 8:13am
2
When you installed the SSL cert
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
I watched the video and did it step by step until the above screen.
It never steped to the next screen like the video, but when I check I get this in the foto below
I did it. After the 15 minutes what should I do?
Everything will be done automatically?
KangJL
August 17, 2022, 9:11am
6
Nothing. Looks ok to me
Remember to do this (just in case it is still http)
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
Admin
August 17, 2022, 10:23am
8
It depends on the vendor. With Let’s Encrypt it’s about 30 seconds, with ZeroSSL it’s about 10 minutes and with GoGetSSL it’s about 30 minutes.
