mrserox
November 13, 2019, 9:10am
1
I am trying to make my website secure.
Domain
Error
fewcharecords.epizy.com
DNS problem: NXDOMAIN looking up TXT for _acme-challenge.fewcharecords.epizy.com
Mx records appear to have been entered
Where do I get a valid certificate to upload? I have completed the ‘generate key’ but dont see the cert to upload?
Niekon
November 13, 2019, 9:52am
2
SSL certificates are issued by people that provide SSL security. You’ll have to pay for a certificate to get one. There are free ones as well, but Infinityfree does not support most of them.
You can use Cloudflare for your CDN and SSL.
mrserox
November 13, 2019, 9:54am
3
Thanks. I have setup/enabled CloudFlare but didnt seem to work, i will check this part again.
mrserox
November 13, 2019, 9:56am
4
actually CloudFlare not working, see below error.
CLOUDFLARE ERROR : We were unable to identify fewcharecords dot epizy dot com as a registered domain. Please ensure you are providing the root domain and not any subdomains (e.g., example.com , not subdomain.example.com )
Niekon
November 13, 2019, 9:58am
5
That’s because you are using a subdomain of epizy.com . If you want Cloudflare, you need to have a custom URL like http://mysite.com .
You can get those for free from Freenom.com
mrserox
November 13, 2019, 10:15am
6
the free URLs (fewcharecors.tk) from Freenom do not appear to be accepted on Cloudflare.
When i go into Cloudflare it only has fewcharecords.epizy DOT com showing
Niekon
November 13, 2019, 10:21am
7
.tk websites are not allowed in Infinityfree.
system
Closed
December 13, 2019, 10:39am
10
