Error:
Please set up the following CNAME record on your domain name.
This record is necessary for the certificate provider to verify you own the domain name.
Current Destination (no CNAME found)
We did not detect any nameservers on your domain name.
Please make sure that your domain name is active and set up correctly with the provider of the domain name.
Hi everyone.
I was trying to renew the SSL certificates for two websites. One of them has its DNS records managed by Cloudflare. I checked the forums and it seems like an issue many are facing recently. I am not an expert but I decided to do a sort of quick investigation.
For the website which DNS are managed by Cloudflare: My setup has been working for years already. When I try to renew the SSL, I get the error shown above, and in the “SSL certificates” page it appears with the notification “Action required”. This happens for both SSL providers.
For the other website: When I try to renew the SSL using Let’s Encrypt, I move to the next screen and it says that the order is successful and I click to install it and it shows that it needs 10 minutes…You know, the usual. However, I noticed that the expiration date shown is the same as the SSL certificates that is already installed. In the “SSL certificates” page, it doesn’t appear (probably because it may be the same as the already installed one) and I don’t get an email that an SSL order has been issued. When I try to renew the SSL using Google Trust SSL, I get the error shown above, and in the “SSL certificates” page it appears with the notification “Action required”.
Personally, I don’t believe that the error has anything to do with CNAME or anything like that. If I go to “Domains” page, and click on “manage” on each of the domains, I see the same error exists in both:
No nameservers were found on your domain name
Please check the settings at your domain provider. To use InfinityFree, set your nameservers to ns1.epizy.com and ns2.epizy.com.
I believe that this is the origin of all the troubles. It seems like the system is failing to get/read the nameservers setup on the domains even though one of the domains has ns1.epizy.com and ns2.epizy.com as nameservers. I am not sure whether this is happening with everyone or every domain registrar, but the one I am using is NameSilo. Using ICANN Lookup, it shows ns1.epizy.com and ns2.epizy.com as nameservers which means that is not an issue from NameSilo but an issue from InfinityFree DNS detection/lookup.
Thank you all for your help in advance. I hope the info I provided will help solve this issue.
Regards
P.S.: I had to post this as “Uncategorized” since the URL input in the “Hosting Support” form is not working.
