SSL certificate will soon expire
My SSL certificate will soon expire and I can’t update it! They keep saying (Custom SSL certificates are no longer supported for free subdomains. All free subdomains have SSL by defauling () so what will I do now??
if you’re using a free subdomain, you don’t need to do anything. Just keel using your site with https:// and no www.
Thanks for your response! But it keeps showing me that my website is not secure, like a danger sign
is your site automatically redirecting to the www. version?
if you’re using a tool like wordpress or sitepro then you may need to change that in the settings
What is your domain?
