Username - epiz_30659951
lvphan.xyz
A trusted SSL Certificate was not found
I get this error when trying to install my WP on https://www.lvphan.xyz through Softaculous.
I installed/uploaded the SSL cert already.
lvphan.xyz
I believe you can safely ignore that error and continue with the installation. Remember though, when the install finishes, you may want to install a plug-in like Really Simple SSL to redirect all of your traffic to the SSL version of your site.
You should proceed with installation via http instead of https
Then do this
You were correct, I was able to ignore that error and continue with the installation.
Thank you!
