I got free SSL certificate from InfinityFree and now im having issue about error message.
Safari sees my website as an untrusted website.
In google it works well without any problem.
What should i do now?
For starters, you should not hide the domain name when asking why something on your domain doesn’t work. If we don’t know the domain name, we can’t verify there is a problem, let alone fix it.
There are many different reasons why you could see an error like this. We need more information to narrow it down.
So please tell us the domain name so we can try to help you.
My website is : https://wezahar.online
Hi, I’ve just checked the site and as you mentioned, it does work well on google chrome.
This means that it is simply just an issue with your safari browser, which has probably cached your data to improve page load time - including some outdated information relating to your site’s encryption.
The simple fix for this is to clear your cache, and this varies based on your iOS device.
Yeah mate i just removed all codes for now, actually yesterday i asked to my friends to check my website from just ios device , some of them worked well ,but in some of them pop up this error message.
I couldnt understand what happening still.
Btw thank you for checking mate.
Hey dude , firstly thank you for your reply.
I asked to my friends to check my website from just ios device , some of them worked well ,but in some of them pop up this error message.
I dont have any idea about why its happening, i want to be sure that my website works well on every browsers.
No problem
Then I would guess they visited your website at least once before you added your SSL, so their devices are still storing old data. They would have to clear their temporary browser data and cache using the steps I provided above. For any new users like myself, it would work fine.
Yeah might be bro ,but they visited first time and they also asked to their friends. Situation complicated little bit, i cant figure out why just this problem happining only in safari. Weird…
