SSL certificate problem
Hi, my user name is epiz_30088619. My website is monomole.com.
I’ve installed my SSL certificate (expiring in 16 Jan 2022) and it is reflected in my SSL status as ‘valid SSL certificate is installed’. However, when I open my website with https in different browsers and devices after clearing cache, I get the ‘your connection to this site is not secure’ message. I’ve also tried using the Really Simple SSL plugin to force visitors to HTTPS, but is unable to proceed beyond the generate SSL step. What am I missing here? Please help.
Seems pretty secure to me:
If you’re using Really Simple SSL, please note that you (probably) cannot use that plugin to generate the SSL for you. And you don’t need to, because you’ve already requested a certificate through us and installed it. All Really Simple SSL needs to do is update your website URL and force HTTPS. Which, to be honest, can be done quite easily without a plugin.
