SSL Certificate not trusted in Safari
https://ihss.icu/
Recently when I tried to visit the website via https, the browser said connection is not private on Safari. And seems that problem exists on iPhone and iPad. This does not happen in Android browsers though.
Update: When I checked the Let’s encrypt website, it says the SSL certificate will no longer be supported from October 2021 onwards if the browser does not trust DST Root CA X3.
Please check to see if there are any solution to this. Thanks.
I have just opened it on my safari on a mac and it works fine for me. Im on safari version 14.1.2
You can switch to another provider from app.infinityfree.net/ssls. Try ZeroSSL or GoGetSSL.
I am using free hosting and it doesn’t seem possible. How to switch provider?
Click on the link, than select ZeroSSL or GoGetSSL
