SSL Certificate Issue – "Connection Not Secure" Warning
Hi everyone,
I’m facing an issue with my SSL certificate. After installing it, the status shows as “Active,” and everything works fine. However, after a few days, the browser starts displaying the message “The connection to this site is not secure.”
When I check the SSL certificate settings and go to “Manage SSL Certificate,” I reinstall it, even though it appears to already be installed. After reinstalling, the site works fine again, but eventually, the same “not secure” warning appears.
Details:
  • Issuer: Google Trust Services
  • Expires at: 2025-02-26
Has anyone experienced a similar issue or have any suggestions on how to fix this? I’d appreciate any help or guidance!
Thanks in advance!
Did you do this?
