SSL Certificate installed but status remains "Not Found"
KIDUSBERHANU.COM
issue Description:
I am having an issue getting my new SSL certificate to activate. I have been using the same process to renew my certificates on this account for the past year without any problems, but this time it is not working.
Details:
  1. I requested the certificate and clicked the “Install SSL Certificate Automatically” button.
  2. I received the green success message stating: “The SSL certificate has been installed! It may take up to 1 hour for it to become active.”
  3. However, under Step 5: Verify Installation, the status still shows as “Not Found” (red label).
  4. When I visit my website via HTTPS, it still shows a “Not Secure” warning.
I have waited for the suggested time, but the control panel does not seem to recognize the installation. Could you please check if the certificate was correctly pushed to the hosting server for my account?
Hello, and Welcome back to the InfinityFree Forum! It’s been 2 years since we have seen you!
I’m seeing the same issue as well. Did you create/push an SSL for the right domain?
Otherwise, you may have to wait for Admin.
No issue
Please note that it can take some time for the certificate to become active. The message says 1 hour, but I think that that estimation might be on the low side.
I just checked it and the certificate is active now.
So it doesn’t look like anything went wrong, it just took a little bit longer than expected.
I’m having the same trouble, I installed it on Friday 16-01-2026 and still showing not found.
What’s the domain name?
linguaconect.com
When I visit https://linguaconect.com/, I see a valid Let’s Encrypt certificate. The SSL Status checker in our panel also confirms the certificate is correctly setup.
If you don’t see an SSL certificate, it’s simply because you are not using HTTPS. Your website supports HTTPS now, but doesn’t appear to be enforcing it yet.
If you want that, you’ll need to configure it in your own website:
I just tried now and now it’s working thanks
