SSL certificate error for subdomain
https://web-work.gamer.gd
Hi! this is my website. I use a free subdomain and I know that SSL certificate should be automatically active for all subdomains, but when I try to open my website it shows this error: Attackers can steal your data from web-work.gamer.gd (for example, passwords, message data, or credit cards).
NET::ERR_CERT_AUTHORITY_INVALID
I don’t use www, it has the https, and I can’t figure out what’s the problem and what to do, can you please help?
No issue
All free subdomains are protected with SSL certificates from ZeroSSL, a big and well known SSL certificate provider.
If your browser is telling you that the SSL certificate used is from an untrusted provider, that could either mean:
  • The required data to validate ZeroSSL certificates is missing on your computer. That could be caused by using an outdated browser and/or operating system.
  • The connection between you and our servers is being intercepted by a third party, who is trying to impersonate your website by sending a fake SSL certificate, which your browser (correctly) blocks.
Please check if any of these things might be happening on your end.
I guess it’s my internet problem, because I tried to open it in different browser and even tried on another PC, but I still get same issue. Anyway, thank you for your reply!
