SSL certificate chain is incomplete
studiovectorio.com
Hello InfinityFree Support,
I am experiencing an SSL issue with my domain: studiovectorio.com.
According to the SSL Labs test, the certificate chain is incomplete, which causes the SSL grade to be capped at B. It appears that the intermediate certificate is missing.
I have already installed the SSL certificate, but the issue still exists.
Could you please check whether the server is correctly serving the full certificate chain and help resolve this issue?
Server IP: 185.27.134.113
Thank you for your time and assistance.
Welcome to the forum
Your site is secure and the ssl certificate is working.
SSL labs has a real problem with the ssl certificates here. Im not sure why, but as long as your page shows as secure when you access it i wouldn’t worry about it
Intermediate/chained certificates are not supported here so if you have a custom domain you’ll always have this issue. Unfortunately it’s not something you can fix.
You could try using cloudflare and their ssl tools since you’ve for a custom domain
