Hello. My domain kromaplay.com.br has an Active Let’s Encrypt certificate in the InfinityFree panel, but the live server still sends an incomplete certificate chain. OpenSSL returns: Verify return code: 21 (unable to verify the first certificate). DNS points to 185.27.134.118. The website works in some browsers, but Android WebView refuses to load it. Please fix or reinstall the full SSL certificate chain on the active server.
For what its worth, given that you’re using a custom domain, not an InfinityFree sub domain, you may be better looking at using cloudflare and their SSL tools. This gives you added DDOS protection as well.
Yes, that’s normal. Uploading CA chains along with a certificate is not supported on our hosting, and 99% of browsers have no problem with that at all and will resolve the required certificates themselves.
