http://ghassan-hamadani.epizy.com/newCode/public/
SELECT
FROM
`sessions`
WHERE
`id` = RYqiJnO6ET2c2r18vw15Et1kycxqzYYFylrI0LHH
limit
1
I’m using Laravel 9
SELECT
FROM
`sessions`
WHERE
limit
1
I’m using Laravel 9
Your post contains no useful information in order to address the issue, please provide the database credentials which laravel uses to connect. (Censor the password)
Shouldn’t this part be in quotes?
(Optionally, since everything else is UPPERCASE, apply this to limit too):
SELECT
FROM
`sessions`
WHERE
`id` = 'RYqiJnO6ET2c2r18vw15Et1kycxqzYYFylrI0LHH'
LIMIT
1
Laravel removes those quotation marks when printing out the query for some reason, one simple proof would be that trying to inject SQL into it will fail.
Hi Mouhamad,
There is nothing wrong with the SQL statement. Connection refused simply means wrong password or wrong hosting address information from your config/database.php or .env.
Check and update the information under connections > mysql to the values provided in the client area > MySQL database. Then update the values to match those in the client area. Once that’s done, make sure your default connection is set to mysql, then try again.
Cheers!
and this is my code in .env
DB_CONNECTION=mysql
DB_HOST=sql310.infinityfree.com
DB_PORT=3306
DB_DATABASE=epiz_23225434_gh
DB_USERNAME=epiz_23225434
DB_PASSWORD=*******
Hi Mouhamad,
Assuming you have pasted in the correct password, then you might want to check if the config/database.php file is taking values from the .env file, and update those lines if not.
Cheers!
I changed my config/database.php to this:
'mysql' => [
'driver' => 'mysql',
'url' => env('DATABASE_URL'),
'host' => 'sql310.infinityfree.com',
'port' => '3306',
'database' => 'epiz_23225434_gh',
'username' => 'epiz_23225434',
'password' => *******,
'unix_socket' => env('DB_SOCKET', ''),
'charset' => 'utf8mb4',
'collation' => 'utf8mb4_unicode_ci',
'prefix' => '',
'prefix_indexes' => true,
'strict' => true,
'engine' => null,
'options' => extension_loaded('pdo_mysql') ? array_filter([
PDO::MYSQL_ATTR_SSL_CA => env('MYSQL_ATTR_SSL_CA'),
'mysql' => [
'port' => 3306,
// 'unix_socket' => env('DB_SOCKET', ''),
'prefix' => '',
'strict' => true,
'engine' => null,
still connection refused
Consider creating a new database and export/import the data over via phpMyAdmin option in the client area, plug in new values and try again.
I tried a pure PHP code to connect to the database and it worked just fine, so I don’t know what is the problem
Change this line
to
'url' => null,
Maybe this helps.
nothing
I tried this and it’s working, but as Laravel connection is not:
$servername = "sql310.epizy.com";
$username = "epiz_23225434";
$password = "******";
$db = "epiz_23225434_gh";
// Create connection
$conn = new mysqli($servername, $username, $password, $db);
// Check connection
if ($conn->connect_error) {
die("Connection failed: " . $conn->connect_error);
else
echo "Connected successfully";
$sql = "SELECT * FROM sessions Where id = 'GQItf5A9rt6N3z7V2JiK2tGblkbT7De7Ag2TcavP'";
$result = $conn->query($sql);
if ($result->num_rows > 0) {
// output data of each row
while($row = $result->fetch_assoc()) {
print_r($row)."<br>";
} else {
echo "0 results";
$conn->close();
exit();
$servername is different, try using this value instead.
I used and still connection refused
fixed,
the problem was in the cache, I just deleted my cache files, and it worked just fine ![]()
