SQLSTATE[HY000] [2002] Connection refused
http://files.refempire.xyz/
SQLSTATE[HY000] [2002] Connection refused (SQL: select * from information_schema.tables where table_schema = forge and table_name = migrations)
codecanyon script bedrive
Remote MYSqL Is not here, you can only use sql on InfinityFree’s servers
it’s using regular mysql and not remote
What is your server name is your config file? Because here SQL is not localhost, Also have you double checked your password and username?
double checked all
and what do u mean by server name? and config file
You will have a ‘mysql host’ or ‘mysql server’
sql210.epizy.com
Follow the tips here;
Помогли. Спасибо.
Translation by MOD: They helped. Thank.
what ?
