Sql207.epizy.com doesn't load
Username: epiz_33668285
sql207.epizy.com
none
i tried to access MySQL database. however, the website takes a very long time to load.
What are you trying to do, exactly? You cannot access the SQL domain directly. If you want to access your database, you can do so via PHPMyAdmin from the control panel.
If you have an error with your website’s connection to the database, this post may help:
