Sql105.epizy.com is not running
My website URL is:
What I’m seeing is:
This either means that the username and password information in your wp-config.php file is incorrect or we can’t contact the database server at sql105.epizy.com . This could mean your host’s database server is down.
  • Are you sure you have the correct username and password? YES
  • Are you sure that you have typed the correct hostname? YES
  • Are you sure that the database server is running? NO
Additional information:
I upload correctely a new wordpress installation. Configured correctly the database. But the installation failles because it seems the database server sql105.epizy.com is not running.
Hi
https://infinityfree.net/support/how-to-install-wordpress/
https://infinityfree.net/support/common-mysql-errors/
