Special Characters are not showing correctly
in the tables or selects that have the data source from the database the special characters like “~” are not showing. i even applied the htmlspecialchars(), but its not doing anything.
this an part from the code of an table that i have and this is how i apply the htmlspecialcharacters():
$cell_data = htmlspecialchars($source_t[$i][$h_columns[$j]],true);
                                if (strtoupper($h_columns[$j])=="ESTADO")
                                    echo"<td>
                                            <div class=checkbox-wrapper-35>
                                                <input type = hidden name = bk_mode_id[] value = ". ((boolval($cell_data) == true) ? "true" : "false") .">
                                                <input type = hidden name = mode_id[] value = ". ((boolval($cell_data) == true) ? "true" : "false") .">
                                                <input name=check_mode[] id=state_". $source_t[$i]['ID'] ." type=checkbox class=switch
                                                ".((boolval($cell_data) == true) ? "checked" : "")." onclick = hide_show_bt(this) value =". ((boolval($cell_data) == true) ? "true" : "false") .">
                                                <label for=state_". $source_t[$i]['ID'] .">
                                                    <span class=switch-x-toggletext>
                                                        <span class=switch-x-unchecked><span class=switch-x-hiddenlabel>Unchecked: </span>Fechada</span>
                                                        <span class=switch-x-checked><span class=switch-x-hiddenlabel>Checked: </span>Aberta</span>
                                                    </span>
                                                </label>
                                            </div>
                                        </td>";
                                else
                                    echo "<td>$cell_data</td>";
please provide url , and try to add charset utf-8 to you db connection file
http://intervencoescc.infy.uk/login.php
i can use the account teste. pass = teste
I had a similar problem and i needed to add “charset=utf8mb4” into my connection string when connecting to the database and that fixed it.
My php looked like this
new PDO("mysql:host=$servername;dbname=$dbname;charset=utf8mb4", $username, $password);
Might be worth a try.
