This is verified
(Byet Host)
(ProFreeHost)
This can somehow tell that the mofh infrastructure is poorly developed(its panel doesn’t have a sort of upstream reseller check) ![]()
This is verified
(Byet Host)
What do you mean? I’m pretty sure the ability to login to any cpanel domain was toted as a feature at some point.
Also, any customizations the host owner made (Like adding in advertisements) should be loaded when you login via a different panel.
It was even better some years ago, where logging in to another reseller’s panel would log you in with your own account, but with the panel configuration of the reseller you were logging in to. This was changed afterwards; I don’t exactly remember why.
Yep, althought it wasn’t always like this ![]()
I disagree in the spirit that if someone has broken their own reseller, their user could still get a backup by logging in to a different panel that isn’t broken with the reseller’s configuration.
/login.php and putting something like this after the URL: /><h1>someone XSS'd this before me lolz ~05</h1>. The vulnerability was patched on Jul 09 2023 08:27:50 (that’s when I recieved ticket update)
Just discorvered this:
There is a real cPanel instance running on https://epizy.com:2083/ , which is probably used by iFastNet themselves.
Similar addresses like rf.gd:2083 , free.nf:2083 didn’t work though. That’s what make me think this panel belongs to ifn.
It gives a redirect to you?
For me it just stays in epizy.com .
That’s one of the cPanel’s features I think
Yup, I checked.
Most of the free subdomain base domains are on an iFastNet premium account.
Fun fact: the base domains get so much traffic that even serving 301 redirects with .htaccess rules far exceeds the 50k hits limit.
Just found another fact:
infinityfreeapp.com is registered on XVHOST
