I have so far tried multiple times, and it is not working correctly. When i tried to install to a folder, the url goes to a IP address 127.0.0.7 which I believe is a local IP address. How to get it to install correctly ? and ensure it points to a real IP address on infinityfree ?
I’m sorry, but how is it not installing properly? Does Softaculous show an error? Or does Softaculous complete without errors and does the site not work?
Also, could you include a URL on the site so we can actually see what the issue is rather than have to guess?
Softaculous does not show an error. It shows it finished installing 100%. But the url it gives in this case it gave sunil.epizy.com/invoice for accessing invoiceplane after the installation is complete, goes to 127.0.0.9 when I try to go to that url. By default, thats the directory it installs in.
I also have taken screenshots during installation, but the attach image file on this interafce is not opening the dialog box to attach file.
Following are the messages and url I get, after installation
Congratulations, the software was installed successfully
I am using a Ubuntu linux Desktop 16.04 LTS and I looked at what version of web server is my machine running and coincidentally it matches. Not sure why http://sunil.epizy.com/invoice is redirecting to the local server
sunil@sunil-OptiPlex-GX620:~$ /usr/sbin/apache2 -v
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2017-09-18T15:09:02
I also tried stopping the web server running on my machine to see if it would do any different, but when I stop the local web server it just fails to load the page instead of 404 since it can not access the web server.
I also checked from another machine to isolate the local web server .
There, the message is 127.0.0.7 refused to connect. When I looked under General php info on cpanel I see that 127.0.0.7 is the local address under Apache Environment
Also I checked the web server address running locally on my machine which is 127.0.0.1 and is different from where the url sunil.epizy.com/invoice is trying to go to. So it does not appear that it is trying to go to my local server, but some setting on Infinity Free side is directing it to 127.0.0.7, and that is not working.
I get the same redirect, but I’m not running a webserver on my machine so I just see a Connection Refused page. 127.0.0.7, just like all other IP addresses starting with 127, is an IP address of the local machine. On your computer, it points to your own computer. On the hosting server, it points to the hosting server.
We run a bit of an unconventional server stack, but most scripts never notice that. InvoicePlane on the other hand seems to look at a the SERVER_ADDR parameter and believes it would be a good idea to redirect visitors to that IP address.
I took a look at the script configuration, but I didn’t see anything that could easily explain this issue. You could try to do a manual installation to circumvent any possible issues with Softaculous, but I have no idea what could be causing this either.
I got around the issue I had before by modifying one of php setting files within the application. But not completely out of the woods yet. Now I am at the step where it needs to connects to database. I have made sure that all the below names are valid but I get
Failure
cannot_connect_database_server
Hostname sql301.epizy.com
The hostname for your database.
Port
3306
The port your hostname is listening on. Default is 3306.
Username
epiz_20788196
Username associated with the database.
Password
Password associated with the database.
Database
epiz_20788196_86
The name of the database you created for InvoicePlane.
Can you please help in identifying why it would not connect to the database. I also checked with host sql301.byetcluster.com as when I connect to it from phpmyadmin thats the host it shows, but that also fails to connect.
